演示源代码
本演示中的资源代码仅作为参考。
2.4inch_LCD_demo.py:
#!/usr/bin/python ''' Please make sure the 2.4inch LCD Moudle is connected to the correct pins. The following table describes how to connect the 2.4inch LCD Module to the 40-pin header. ------------------------------------------------- __2.4inch LCD Module___Pin Number_____Pin Name VCC 17 3.3 V Power GND 39 GND DIN 19 SPI MOSI CLK 23 SPI SCLK CS 24 SPI CE0 DC 40 GPIO44 RST 11 GPIO42 BL 18 GPIO51 ------------------------------------------------- ''' import os import sys import time import logging from PIL import Image sys.path.append("..") import VisionFive.boardtype as board_t from lib import LCD2inch4_lib ''' Demo modification ans new function description ------------------------------------------------------------ I. add the clear() function to fill LCD screen with white II. give a hexadecimal value of white III. cycle through multiple pictures --------------------------------------------------------------- ''' WHITE = 0xFF def main(): print('-----------lcd demo-------------') #Determining cpu Type: 1 means visionfive1; 2 means visionfive 2 vf_t = board_t.boardtype() if vf_t == 1: SPI_DEVICE = "/dev/spidev0.0" elif vf_t == 2: SPI_DEVICE = "/dev/spidev1.0" else: print('This module can only be run on a VisionFive board!') return 0 """The initialization settings of 2inch and 2.4inch are distinguished""" disp = LCD2inch4_lib.LCD_2inch4(11, 40, SPI_DEVICE) #disp.lcd_init() disp.lcd_init_2inch4() disp.lcd_clear(WHITE) if vf_t == 1: image = Image.open('./visionfive.bmp') elif vf_t == 2: image = Image.open('./visionfive2.bmp') else: return disp.lcd_ShowImage(image, 0, 0) time.sleep(2) """add the part of displaying pictures circularly""" while True: print(time.strftime("%Y-%m-%d %H:%M:%S",time.localtime(time.time()))) """rotate the picture 90 degrees anticlockwise""" """to keep consistent with the display direction of other pictures""" image = Image.open('./LCD_2inch4_parrot.bmp') image = image.transpose(Image.Transpose.ROTATE_90) disp.lcd_ShowImage(image, 0, 0) image = Image.open('./LCD_2inch.jpg') disp.lcd_ShowImage(image, 0, 0) if __name__=="__main__": main()LCD2inch4_lib.py:
import os import sys import time import logging import VisionFive.spi as spi import VisionFive.gpio as gpio import numpy as np from PIL import Image,ImageDraw,ImageFont class LCD_2inch4(): width = 240 height = 320 def __init__(self, rst_pin, dc_pin, dev): self.rstpin = rst_pin self.dcpin = dc_pin self.spidev = dev spi.getdev(self.spidev) #Reset the maximum clock frequency of communication. #The display speed of the picture is positively correlated with the clock frequency. spi.setmode(40000000, 0, 8) gpio.setup(self.rstpin, gpio.OUT) gpio.setup(self.dcpin, gpio.OUT) def __del__(self): spi.freedev() #Add a short delay for each change of electrical level. def lcd_reset(self): gpio.output(self.rstpin, gpio.HIGH) time.sleep(0.01) gpio.output(self.rstpin, gpio.LOW) time.sleep(0.01) gpio.output(self.rstpin, gpio.HIGH) time.sleep(0.01) def lcd_spisend(self, data): spi.transfer(data) def lcd_sendcmd(self, cmd): gpio.output(self.dcpin, gpio.LOW) spi.transfer(cmd) def lcd_senddata(self,data): gpio.output(self.dcpin, gpio.HIGH) spi.transfer(data) #Write multiple bytes. def lcd_sendnbytes(self, data): gpio.output(self.dcpin, gpio.HIGH) spi.write(data) #Common registers' initialization of the 2.4inch LCD module. def lcd_init_2inch4(self): self.lcd_reset() self.lcd_sendcmd(0x11) #Sleep out. self.lcd_sendcmd(0xCF) #Power Control B. self.lcd_senddata(0x00) self.lcd_senddata(0xC1) self.lcd_senddata(0x30) self.lcd_sendcmd(0xED) #Power on sequence control. self.lcd_senddata(0x64) self.lcd_senddata(0x03) self.lcd_senddata(0x12) self.lcd_senddata(0x81) self.lcd_sendcmd(0xE8) #Driver Timing Control A. self.lcd_senddata(0x85) self.lcd_senddata(0x00) self.lcd_senddata(0x79) self.lcd_sendcmd(0xCB) #Power Control A. self.lcd_senddata(0x39) self.lcd_senddata(0x2C) self.lcd_senddata(0x00) self.lcd_senddata(0x34) self.lcd_senddata(0x02) self.lcd_sendcmd(0xF7) #Pump ratio control. self.lcd_senddata(0x20) self.lcd_sendcmd(0xEA) #Driver Timing Control B. self.lcd_senddata(0x00) self.lcd_senddata(0x00) self.lcd_sendcmd(0xC0) #Power Control 1. self.lcd_senddata(0x1D) #VRH[5:0] self.lcd_sendcmd(0xC1) #Power Control 2. self.lcd_senddata(0x12) #SAP[2:0], BT[3:0]. self.lcd_sendcmd(0xC5) #VCOM Control 1. self.lcd_senddata(0x33) self.lcd_senddata(0x3F) self.lcd_sendcmd(0xC7) #VCOM Control 2. self.lcd_senddata(0x92) self.lcd_sendcmd(0x3A) #COLMOD: Pixel Format Set. self.lcd_senddata(0x55) self.lcd_sendcmd(0x36) #Memory Access Control. self.lcd_senddata(0x08) self.lcd_sendcmd(0xB1) #Frame rate control(in normal mode/full colors). self.lcd_senddata(0x00) self.lcd_senddata(0x12) self.lcd_sendcmd(0xB6) #Display function control. self.lcd_senddata(0x0A) self.lcd_senddata(0xA2) self.lcd_sendcmd(0x44) #Set_Tear_Scanline self.lcd_senddata(0x02); self.lcd_sendcmd(0xF2) #Gamma Function Disable self.lcd_senddata(0x00) self.lcd_sendcmd(0x26) #Gamma curve selected. self.lcd_senddata(0x01) self.lcd_sendcmd(0xE0) #Set Gamma. self.lcd_senddata(0x0F) self.lcd_senddata(0x22) self.lcd_senddata(0x1C) self.lcd_senddata(0x1B) self.lcd_senddata(0x08) self.lcd_senddata(0x0F) self.lcd_senddata(0x48) self.lcd_senddata(0xB8) self.lcd_senddata(0x34) self.lcd_senddata(0x05) self.lcd_senddata(0x0C) self.lcd_senddata(0x09) self.lcd_senddata(0x0F) self.lcd_senddata(0x07) self.lcd_senddata(0x00) self.lcd_sendcmd(0XE1); #Set Gamma. self.lcd_senddata(0x00) self.lcd_senddata(0x23) self.lcd_senddata(0x24) self.lcd_senddata(0x07) self.lcd_senddata(0x10) self.lcd_senddata(0x07) self.lcd_senddata(0x38) self.lcd_senddata(0x47) self.lcd_senddata(0x4B) self.lcd_senddata(0x0A) self.lcd_senddata(0x13) self.lcd_senddata(0x06) self.lcd_senddata(0x30) self.lcd_senddata(0x38) self.lcd_senddata(0x0F) self.lcd_sendcmd(0x29) #Display On. def lcd_setPos(self, Xstart, Ystart, Xend, Yend): self.lcd_sendcmd(0x2a) self.lcd_senddata(Xstart >>8) self.lcd_senddata(Xstart & 0xff) self.lcd_senddata((Xend - 1) >> 8) self.lcd_senddata((Xend - 1) & 0xff) self.lcd_sendcmd(0x2b) self.lcd_senddata(Ystart >>8) self.lcd_senddata(Ystart & 0xff) self.lcd_senddata((Yend - 1) >> 8) self.lcd_senddata((Yend - 1) & 0xff) self.lcd_sendcmd(0x2C) def lcd_clear(self, color): #Clear contents of image buffer. _buffer = [color]*(self.width * self.height *2) self.lcd_setPos(0, 0, self.width, self.height) gpio.output(self.dcpin, gpio.HIGH) #Multi-byte-write. self.lcd_sendnbytes(_buffer) def lcd_ShowImage(self, Image, Xstart, Ystart): #Set buffer to the value of the Python Imaging Library image. #Write display buffer to the physical display. imwidth, imheight = Image.size if imwidth == self.height and imheight == self.width: img = np.asarray(Image) pix = np.zeros((self.width, self.height,2), dtype = np.uint8) pix[...,[0]] = np.add(np.bitwise_and(img[...,[0]],0xF8),np.right_shift(img[...,[1]],5)) pix[...,[1]] = np.add(np.bitwise_and(np.left_shift(img[...,[1]],3),0xE0), np.right_shift(img[...,[2]],3)) pix = pix.flatten().tolist() self.lcd_sendcmd(0x36) #Define read/write scanning direction of frame memory. self.lcd_senddata(0x78) self.lcd_setPos(0, 0, self.height, self.width) gpio.output(self.dcpin, gpio.HIGH) #Multi-byte-write. self.lcd_sendnbytes(pix) else : img = np.asarray(Image) pix = np.zeros((imheight, imwidth, 2), dtype = np.uint8) pix[...,[0]] = np.add(np.bitwise_and(img[...,[0]],0xF8),np.right_shift(img[...,[1]],5)) pix[...,[1]] = np.add(np.bitwise_and(np.left_shift(img[...,[1]],3),0xE0), np.right_shift(img[...,[2]],3)) pix = pix.flatten().tolist() self.lcd_sendcmd(0x36) self.lcd_senddata(0x08) self.lcd_setPos(0, 0, self.width, self.height) gpio.output(self.dcpin, gpio.HIGH) #Multi-byte-write. self.lcd_sendnbytes(pix)
