演示源代码
本演示中的资源代码仅作为参考。
RPi_demo_#PWM#_run_on_VisionFive.py:
#import RPi.GPIO as GPIO #******************************************************* #Note: above command must be replaced with command below import VisionFive.gpio as GPIO #******************************************************* from time import sleep ledpin = 36 # PWM pin connected to LED GPIO.setwarnings(False) # disable warnings GPIO.setmode(GPIO.BOARD) # set pin numbering system GPIO.setup(ledpin,GPIO.OUT) pi_pwm = GPIO.PWM(ledpin,1000) # create PWM instance with frequency pi_pwm.start(0) # start PWM of required duty cycle while True: for duty in range(0,101,1): pi_pwm.ChangeDutyCycle(duty) # provide duty cycle in the range 0-100 sleep(0.01) sleep(0.5) for duty in range(100,-1,-1): pi_pwm.ChangeDutyCycle(duty) sleep(0.01) sleep(0.5)
