演示源代码
本演示中的资源代码仅作为参考。
uart_gps_demo.py:
Please make sure the NEO-6M is connected to the correct pins.
The following table describes how to connect NEO-6M to the 40-pin header
Passive Buzzer___Pin Number_____Pin Name
    VCC             4           5 V Power
    GND             6             GND
    TXD             10          UART RX
    RXD             8           UART TX
import sys
import serial
import time
#Reference information of the GPGSA format.
Example 1 (GPS only):
$GPGSA,M,3,17,02,30,04,05,10,09,06,31,12,,,1.2,0.8,0.9*35
Example 2 (Combined GPS and GLONASS):
$GNGSA,M,3,17,02,30,04,05,10,09,06,31,12,,,1.2,0.8,0.9*2B
$GNGSA,M,3,87,70,,,,,,,,,,,1.2,0.8,0.9*2A
SN      Field
                                Symbol
                                            Example
1       $GPGSA
                Log header.For information about the log headers, see ASCII, Abbreviated ASCII or Binary.
                                N/A
                                            $GPGSA
2       mode MA
                Mode: 1 = Fix not available; 2 = 2D; 3 = 3D
                                x
                                            3
3       mode 123
                Latitude (DDmm.mm)
                                llll.ll
                                            5106.9847
4-15   prn
                PRN numbers of satellites used in solution (null for unused fields), total of 12 fields
                GPS = 1 to 32
                SBAS = 33 to 64 (add 87 for PRN number)
                GLO = 65 to 96
                                xx,xx,.....
                                            18,03,13,25,16,24,12,20,,,,
The detail info, please see https://docs.novatel.com/OEM7/Content/Logs/GPGSA.htm?tocpath=Commands%20%2526%20Logs%7CLogs%7CGNSS%20Logs%7C_____63
GPGSA_dict = {
"msg_id":  	0,
"mode1":  	1,
"mode2":  	2,
"ch1":          3,
"ch2":          4,
"ch3":          5,
"ch4":          6,
"ch5":          7,
"ch6":          8,
"ch7":          9,
"ch8":          10,
"ch9":          11,
"ch10":         12,
"ch11":         13,
"ch12":         14,
#Reference information of the GPGGA format.
SN   Field
                                Symbol
                                            Example
1   $GPGGA
                                N/A
                                            $GPGGA
2   utc
                UTC time status of position (hours/minutes/seconds/ decimal seconds)
                                hhmmss.ss
                                            202134.00
3   lat
                Latitude (DDmm.mm)
                                llll.ll
                                            5106.9847
4   lat dir
                Latitude direction (N = North, S = South)
                                a
                                            N
5   lon
                                yyyyy.yy
                                            11402.2986
6   lon dir
                Longitude direction (E = East, W = West)
                                a
                                            W
7   quality
                refer to Table: GPS Quality Indicators
                                x
                                            1
8   # sats
                Number of satellites in use.May be different to the number in view
                                xx
                                            10
The detail info, please see https://docs.novatel.com/OEM7/Content/Logs/GPGGA.htm?tocpath=Commands%20%2526%20Logs%7CLogs%7CGNSS%20Logs%7C_____59
GPGGA_dict = {
"msg_id":  		0,
"utc":  		        1,
"latitude":             2,
"NorS":                 3,
"longitude":            4,
"EorW":                 5,
"pos_indi":             6,
"total_Satellite":      7,
uart_port = "/dev/ttyS0"
def IsValidGpsinfo(gps):
    data = gps.readline()
    #Convert the data to string.
    msg_str = str(data, encoding="utf-8")
    #Split string with ",".
    #GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30
    msg_list = msg_str.split(",")
    #Parse the GPGSA message.
    if (msg_list[GPGSA_dict['msg_id']] == "$GPGSA"):
            print()
            #Check if the positioning is valid.
            if msg_list[GPGSA_dict['mode2']] == "1":
                print("!!!!!!Positioning is invalid!!!!!!")
            else:
                print("*****The positioning type is {}D *****".format(msg_list[GPGSA_dict['mode2']]))
                print("The Satellite ID of channel {} : {}")
                #Parse the channel information of the GPGSA message.
                for id in range(0, 12):
                    key_name = list(GPGSA_dict.keys())[id + 3]
                    value_id =  GPGSA_dict[key_name]
                    if  not (msg_list[value_id] == ''):
                        print("                           {} : {}".format(key_name, msg_list[value_id]))
    #Parse the GPGGA message.
    if msg_list[GPGGA_dict['msg_id']] == "$GPGGA":
        print()
        print("*****The GGA info is as follows: *****")
        for key, value in GPGGA_dict.items():
            #Parse the utc information.
            if key == "utc":
                utc_str =  msg_list[GPGGA_dict[key]]
                if not utc_str == '':
                    h = int(utc_str[0:2])
                    m = int(utc_str[2:4])
                    s = float(utc_str[4:])
                    print(" utc time: {}:{}:{}".format(h,m,s))
                    print(" {} time: {} (format: hhmmss.sss)".format(key, msg_list[GPGGA_dict[key]]))
            #Parse the latitude information.
            elif key == "latitude":
                lat_str = msg_list[GPGGA_dict[key]]
                if not lat_str == '':
                    Len = len(lat_str.split(".")[0])
                    d = int(lat_str[0:Len-2])
                    m = float(lat_str[Len-2:])
                    print(" latitude: {} degree {} minute".format(d, m))
                    print(" {}: {} (format: dddmm.mmmmm)".format(key, msg_list[GPGGA_dict[key]]))
            #Parse the longitude information.
            elif key == "longitude":
                lon_str = msg_list[GPGGA_dict[key]]
                if not lon_str == '':
                    Len = len(lon_str.split(".")[0])
                    d = int(lon_str[0:Len-2])
                    m = float(lon_str[Len-2:])
                    print(" longitude: {} degree {} minute".format(d, m))
            else:
                print(" {}: {}".format(key, msg_list[GPGGA_dict[key]]))
def main():
    gps = serial.Serial(uart_port, baudrate=9600, timeout=0.5)
    while True:
        IsValidGpsinfo(gps)
        time.sleep(1)
    gps.close()
if __name__ == "__main__":
    sys.exit(main())
