在SD卡和eMMC上扩展分区
登录Debian后,为充分利用SD卡上未使用的空间,请执行以下步骤,扩展昉·星光 2 SD卡和eMMC的分区:
  1. 执行以下命令,列出可使用的磁盘空间:
    ~# df -h
    输出示例:
    Filesystem      Size  Used Avail Use% Mounted on
    udev            3.7G     0  3.7G   0% /dev
    tmpfs           793M  3.1M  790M   1% /run
    /dev/mmcblk1p4  2.0G  1.9G   88M  96% /
    tmpfs           3.9G     0  3.9G   0% /dev/shm
    tmpfs           5.0M   12K  5.0M   1% /run/lock
    tmpfs           793M   32K  793M   1% /run/user/107
    tmpfs           793M   24K  793M   1% /run/user/0
  2. 以磁盘名作为参数运行fdisk命令。
    命令示例:
    root@starfive:~# fdisk /dev/mmcblk<X>
    提示: <X>:变量值为0或1。SD卡取1,eMMC取0。
    示例输出
    root@starfive:~# fdisk /dev/mmcblk1
    Welcome to fdisk (util-linux 2.38.1).
    Changes will remain in memory only, until you decide to write them.
    Be careful before using the write command.
    GPT PMBR size mismatch (4505599 != 62929919) will be corrected by write.
    This disk is currently in use - repartitioning is probably a bad idea.
    It's recommended to umount all file systems, and swapoff all swap
    partitions on this disk.
    Command (m for help): d
    Partition number (1-4, default 4): 4
    Partition 4 has been deleted.
    Command (m for help): n
    Partition number (4-128, default 4): 4
    First sector (34-62929886, default 221184):
    Last sector, +/-sectors or +/-size{K,M,G,T,P} (221184-62929886, default 62928895):
    Created a new partition 4 of type 'Linux filesystem' and of size 29.9 GiB.
    Partition #4 contains a ext4 signature.
    Do you want to remove the signature? [Y]es/[N]o: N
    Command (m for help): w
    The partition table has been altered.
    Syncing disks.
  3. 执行resize2fs命令调整/dev/mmcblk<X>p4分区的大小,以充分利用未使用的块。
    示例命令和输出:
    root@starfive:~# resize2fs /dev/mmcblk1p4
    resize2fs 1.46.6-rc1 (12-Sep-2022)
    Filesystem at /d[  295.372617] EXT4-fs (mmcblk1p4): resizing filesystem from 535291 to 7838464 blocks
    ev/mmcblk1p4 is mounted on /; on-line resizing required
    old_desc_blocks = 1, new_desc_blocks = 4
    [  295.993163] EXT4-fs (mmcblk1p4): resized filesystem to 7838464
    The filesystem on /dev/mmcblk1p4 is now 7838464 (4k) blocks long.
    验证:
    执行df -h命令以验证分区的新大小,并验证扩展分区(/dev/mmcblk<X>p4)的步骤是否成功。
    以下输出表示修改成功:
    root@starfive:~# df -h
    /dev/mmcblk1p4   30G  1.9G   28G   7% /
