扩展分区
登录Debian后,如需充分利用SD卡上未使用的磁盘空间,请执行以下步骤扩展分区:
  1. 执行以下命令,列出可使用的磁盘空间:
    df -h
    输出示例:
    root@starfive:~# df -h
    Filesystem     Size     Used Avail Use% Mounted on
    udev           1.7G        0  1.7G   0% /dev
    tmpfs          390M     1.7M  388M   1% /run
    /dev/mmcblk1p3 4.8G     3.2G  1.6G  68% /
    tmpfs          2.0G        0  2.0G   0% /dev/shm
    tmpfs          5.0M        0  5.0M   0% /run/lock
    tmpfs          390M      32K  390M   1% /run/user/111
    tmpfs          390M      24K  390M   1% /run/user/0
  2. 以磁盘名作为参数运行fdisk命令。
    然后根据您的需求,执行以下命令:
    • 输入d,删除/dev/mmcblk1p3分区;
    • 输入n,创建一个新的分区;
    • 输入w可保存修改。
    示例命令和输出:
    root@starfive:~# fdisk /dev/mmcblk1
    Welcome to fdisk (util-linux 2.38).
    Changes will remain in memory only, until you decide to write them.
    Be careful before using the write command.
    GPT PMBR size mismatch (10485759 != 249737215) will be corrected by write.
    The backup GPT table is not on the end of the device.This problem will be corrected by write.
    This disk is currently in use - repartitioning is probably a bad idea.
    It's recommended to umount all file systems, and swapoff all swap
    partitions on this disk.
    Command (m for help): d
    Partition number (1-3, default 3): 3
    Partition 3 has been deleted.
    Command (m for help): n
    Partition number (3-128, default 3): 3
    First sector (239616-249737182, default 239616):
    Last sector, +/-sectors or +/-size{K,M,G,T,P} (239616-249737182, default 249735167):
    Created a new partition 3 of type 'Linux filesystem' and of size 119 GiB.
    Partition #3 contains a ext4 signature.
    Do you want to remove the signature? [Y]es/[N]o: N
    Command (m for help): w
    The partition table has been altered.
    Syncing disks.
    root@starfive:~#
  3. 执行resize2fs命令调整/dev/mmcblk1p3分区的大小,以充分利用未使用的块。
    示例命令和输出:
    root@starfive:~# resize2fs /dev/mmcblk1p3
    resize2fs 1.46.5 (30-Dec-2021)
    Filesystem at /d[ 192.744328] EXT4-fs (mmcblk1p3): resizing filesystem from 1280507 to
    31186944 blocks
    ev/mmcblk1p3 is mounted on /; on-line resizing required
    old_desc_blocks = 1, new_desc_blocks = 15
    [ 196.934822] EXT4-fs (mmcblk1p3): resized filesystem to 31186944
    The filesystem on /dev/mmcblk1p3 is now 31186944 (4k) blocks long.
    验证:
    执行df -h命令以验证分区的新大小,并验证扩展分区(/dev/mmcblk1p3)的步骤是否成功。
    以下输出表示修改成功:
    tmpfs          390M 1.8M  388M  1%   /run
    /dev/mmcblk1p3 118G 3.3G  114G  3%   /
    tmpfs          390M 32K   390M  1%   /run/user/0
